Constantly having to swap channels
- Re: Constantly having to swap channels
27-01-2011 8:25 PM
Hi, I've been a Plusnet user for about a month now and I'm finding the wireless has problems connecting. Almost everyday I have to connect to the router using the wire and change channels which is quite annoying. Can anyone help?
Message 1 of 4
(9,309 Views)
3 REPLIES 3
27-01-2011 9:41 PM
For reasons best known to themselves, Plusnet are currently sending out Thomson routers which, it has been found, often give problems with wireless. There is an update available for the router firmware that cures most of the wireless problems but Plusnet send out the routers regardless and don't spontaneously tell you about the firmware update.
Message 2 of 4
(411 Views)
27-01-2011 10:00 PM
Thanks RR! Whereabouts do I find this update?
Message 3 of 4
(411 Views)
27-01-2011 10:04 PM
It's ok I've seen it at the sticky at the top. Thanks again!
Message 4 of 4
(411 Views)
