Constantly disconnections all day. Please help
CrystalJayme
I have had lots of disconnections that has caused my speed to be reduced. I have bt hub 6 business as modem and Asus rt-ax82u router. This problem starts midnight so I have to reboot. I'm so fed up.
47 REPLIES 47
Fixes: 306
Re: Constantly disconnections all day. Please help
To even attempt to help you, @CrystalJayme , the Community needs some data.
CrystalJayme
Sorry, what data do you need please?
Fixes: 306
As a minimum, your DSL uptime/data rates/SNR figures and any logs you can provide. If possible, post them as pictures within the message, rather than as attachments.
The results from BT Broadband  - hiding you phone number, and the 'Advanced Diagnostics' from BTW Performance Tester  would also be useful.
CrystalJayme
<p>Here you go</p>
CrystalJayme
My ip profile was at 80mbps before all this started. Can I please have ip profile reset. Thank you
Fixes: 306
Your Hub Manager screenshot says you have had a five hour DSL connection, which implies a problem with the BT/OR network, you have a high D/S SNR - most likely because of the constant disconnections, which have reduced your speeds. Unfortunately, the logs tell us nothing - are they the only ones available?
My suggestion, based on the data supplied, is to (a) check your phone line for noise (dial 17070, select option 2) - after the confirmation of your phone number the ONLY sound you should hear is the regular 'Quiet Line Test' announcement - ANY other noise at all, report a PHONE fault via: https://www.plus.net/help/report-a-problem/phone/ .
If that passes, report a BB issue via: https://www.plus.net/help/report-a-problem/broadband/
Fixes: 306
You need to eliminate the problem before a profile reset will be any good.
CrystalJayme
CrystalJayme
I've noticed the hh6 has the wrong date and month then it reverts back to 5th August
Fixes: 306
Looks like a BT/OR  network problem, but still carry out the phone test please.
CrystalJayme
I did a phone test while last night and it was severe noise on the line which caused my bthh6 to disconnect. After it connected noise went. I'll do another noise test right now and let you know. Thank you for helping me out 😘
CrystalJayme
No noise on the line. I don't know what's causing the noise crackling around midnight. Has bt been having problems at the cabinet Greenhill? I know they've recently installed 5G antenna's there.
CrystalJayme
I just reported to plusnet and they did test on the line and found a fault
CrystalJayme
Thank you John for the advice and the links. Hopefully bt can fix the problem now 👍 😘
