Constant problems...
- Constant problems...
- « Previous
- 1
- 2
- Next »
Re: Constant problems...
06-08-2014 2:28 PM
Yes, that's absolutely fine. Thank you.
Message 16 of 20
(338 Views)
06-08-2014 3:01 PM
Not a problem catherinet556,
Please let us know how you get on with it.
Message 17 of 20
(338 Views)
08-08-2014 12:25 PM
Hello again,
The engineer has been and has fixed everything. Thank you for that.
He had to move the master socket as the wall where it used to be was quite damp for some reason and was damaging the wiring.
Everything seems to work fine now, only minor problem is the speed is only 4mbps.
Will it go back up in time?
Thanks.
Thanks.
Message 18 of 20
(338 Views)
11-08-2014 10:20 AM
Morning catherinet556,
Thanks for giving us an update on this one, glad to hear that the engineer managed to get the issue resolved for you!
As for the speeds, they should return although I have seen that your profile jumped back up to 14300 on Saturday so I would hope that you've already seen this change?
Message 19 of 20
(338 Views)
11-08-2014 10:32 AM
That sounds very expensive to fix - the damp wall that is
Quote from: catherinet556 He had to move the master socket as the wall where it used to be was quite damp for some reason and was damaging the wiring.
Do you know if it is rising damp or a leaky gutter
Message 20 of 20
(338 Views)
- « Previous
- 1
- 2
- Next »
