Constant disconnects
- Constant disconnects
- « Previous
- 1
- 2
- Next »
Re: Constant disconnects
04-11-2009 11:40 AM
leeanthony,
Based on your earlier post, I'd say you're correct - it seems as though the router is dropping the DSL connection - why this wouldn't show up on PN's end is a mystery to me, however...
Message 16 of 19
(185 Views)
05-11-2009 1:15 PM
ok I got the new router today, I let it setup automatically for me with the plusnet wizard thingy.. same as I did with the last one. Other than that the only setting I changed myself was disabling wireless. Is there anything else anyone can recommend me to change to make this thing give me a solid connection?
P.S James there was no returns bag with this, unless thats gona arrive seperately another day?
Some info from the router incase anything needs changed.....
DSL Connection
Link Information
Uptime: 0 days, 0:06:40
DSL Type: G.992.1 annex A
Bandwidth (Up/Down) [kbps/kbps]: 448 / 7,936
Output Power (Up/Down) [dBm]: 11.5 / 19.5
Line Attenuation (Up/Down) [dB]: 21.0 / 36.0
SN Margin (Up/Down) [dB]: 18.0 / 8.5
Vendor ID (Local/Remote): TMMB / TSTC
cant see anythin else worth copy pasting
thx
DSL Connection
Link Information
thx
Message 17 of 19
(185 Views)
Re:Constant disconnects
05-11-2009 4:38 PM
Nope, that looks fairly decent.
No idea where the returns bag is - but that might have been sent out via royal mail, so should turn up some time in early December.
Message 18 of 19
(185 Views)
05-11-2009 6:00 PM
alright then, well il keep onto it and thanks again
Message 19 of 19
(185 Views)
- « Previous
- 1
- 2
- Next »
