Constant disconnects for the past week
Fixes: 334
Re: Constant disconnects for the past week
@MisterW wrote:
@kmw350 Looks like you're either going to have to call customer services or wait for a staff member to pick up this thread.
And hope you get a sensible agent.
kmw350
I'm now typing on my mobile as my internet connection is now completely refusing to connect, just constant flashing or solid orange light. Do you happen to have the phone number as my mobile searching is very slow. Thanks
Fixes: 334
@kmw350 0800 432 0200
kmw350
Thank you. Got through, OR engineer coming tomorrow pm. Nothing more I can do now.
I am very grateful for your help, thanks
kmw350
Surprise surprise, it has now reconnected now that it's been threatened with the OR visit. Smiley
kmw350
Thanks for pointing out the upload capacity Dan, if and when I get this sorted I'll worry about that later, it's not something that affects me too much.
Fixes: 334
From what I've see, Keith, you still need that engineer, and I hope he's a good one.
kmw350
Yep, no change in the past 12hrs, it's still disconnecting every 5 to 30 mins, I hope the engineer can find the cause this afternoon.
kmw350
Well, I did get  a good engineer. I would say his name, but probably shouldn't on a forum. He knew what he was doing, and identified that there was a fault somewhere outside the premises.
He swapped me onto different ports at the cabinet, and it appears it might have immediately fixed it. He then checked as far as he could on his own back towards my house, as far as my lane, (which would require two persons on the poles).
So, if all is well for the next few days to a week, then it is fixed. If disconnects continue to be bad through the weekend, or speeds fall and remain low, I am to report a fault again, and they will return, knowing they will now have to check the poles in my lane (about 250m).
He also fitted a brand new mk4 socket at my house.
I am very grateful for his efforts, it's restored my faith in OR, and I'm keeping my fingers crossed that it has fixed the problem.
Thank you very much @jab1 for your great help, it is reassuring to have this forum with people such as yourself on here, who are willing and able to help.
Fixes: 334
Glad you got a result (and a good engineer), Keith. Hopefully now he has identified and (and fixed) the fault in the cab, you should be OK, but as he said, if things start to go wonky, re-raise the issue.
No need for the thanks - that is what we are here for, although I may not be around much next week as I'm in (hopefully) glorious Devon, but I may be popping in here on the odd evening.
kmw350
Wow.
Just as I posted that message, a massive storm came in, blowing a STRONG gale and raining extremely heavily, and the internet cut out! Typical. As if it isn't awkward enough trouble shooting these issues, but hopefully it is because of the storm this time, hehe.
(My safety plug turned the pc off as well, so I risked turning it back on just to post this).
Fixes: 526
@kmw350 if you wish to praise the engineer, you can do it directly via the Openreach site https://www.openreach.com/help-and-support/thank-an-engineer-form
kmw350
Thanks @MisterW , I will definitely do that.
(It's still looking promising this morning, only one disconnect in the past 16hrs, but that was due to an unrelated power cut this morning, and my speed is already back into the high 40s).
