Constant disconnects all day
jayeffster
My connection has been fine and stable for months. Today its an absolute nightmare dropping me at random moments, sometimes 3 or 4 times in an hour. Been next to impossible to do the stuff I wantd to do today.  Phoned for help and gave up after nearly an hour listening to the same 5 songs. Online testing reckoned it was a phone issue. testing my phone seemed to suggest no dial tone was a factor. Though I can phone out. This might relate to the fact that if someone phones me I get kicked off whatever I was doing. Which is also pretty annoying too.
10 REPLIES 10
Aspiring Legend
Fixes: 194
Re: Constant disconnects all day
Then report a phone fault - although your testing may have already have automatically raised a ticket. If you log into your account, if there is an open one, it should be displayed on the home page.
jayeffster
No ticket that I can see, not that I know what it would show if there was one. I luckily had a spare phone setup which Ive put in place now. Due to the randomness of the drops impossible to say yet if its a fix. I'll have a quick hunt about for another filter too and elimante that as a possible.
Aspiring Legend
Fixes: 194
Try a 'Quiet Line Test' - dial 17070 and select option 2. ANY noise, other than the automated, regular 'quiet line test' message and report a phone fault.
jayeffster
Sounda like a bowl of rice krispies. So guess you are right. Problem is the gigaset handsets need 6 hours to charge and whatnot so I dont even know if theyre non functional until then. I tried to dial out and nothing happened.
Aspiring Legend
Fixes: 194
Then you definitely have a voice-curcuit fault which you will need to report.
jayeffster
Ok well cant do anything for 18 hours while the phone charges, is depleted and charged again Oo
Aspiring Legend
Fixes: 194
You said in post #5 'I tried to dial out and nothing happened'. In that case, a different handset set-up will make no difference. If you have a mobile phone, I would suggest ringing in on 0800 432 0200 as early as possible tomorrow.
jayeffster
Of course but one of the first things in their checklist is test your phone etc and my phones are old. I need to narrow down the possible problems as much as possible.
Aspiring Legend
Fixes: 194
OK.
Fixes: 128
Far easier / much more sensible to go get a cheap corded phone for sub £5 - or borrow one!
Old cordless phone could generate their own noise, which could be mistaken for noise on the line.
Having a working corded phone is a highly valuable diagnostic tool, worth far more than it costs in situations such as this.
