Constant disconnects all day
- Constant disconnects all day
09-05-2021 1:37 AM - edited 09-05-2021 1:38 AM
My connection has been fine and stable for months. Today its an absolute nightmare dropping me at random moments, sometimes 3 or 4 times in an hour. Been next to impossible to do the stuff I wantd to do today. Phoned for help and gave up after nearly an hour listening to the same 5 songs. Online testing reckoned it was a phone issue. testing my phone seemed to suggest no dial tone was a factor. Though I can phone out. This might relate to the fact that if someone phones me I get kicked off whatever I was doing. Which is also pretty annoying too.
Re: Constant disconnects all day
09-05-2021 7:42 AM
Then report a phone fault - although your testing may have already have automatically raised a ticket. If you log into your account, if there is an open one, it should be displayed on the home page.
09-05-2021 12:36 PM
No ticket that I can see, not that I know what it would show if there was one. I luckily had a spare phone setup which Ive put in place now. Due to the randomness of the drops impossible to say yet if its a fix. I'll have a quick hunt about for another filter too and elimante that as a possible.
09-05-2021 12:48 PM - edited 09-05-2021 12:48 PM
Try a 'Quiet Line Test' - dial 17070 and select option 2. ANY noise, other than the automated, regular 'quiet line test' message and report a phone fault.
09-05-2021 12:52 PM
Sounda like a bowl of rice krispies. So guess you are right. Problem is the gigaset handsets need 6 hours to charge and whatnot so I dont even know if theyre non functional until then. I tried to dial out and nothing happened.
09-05-2021 12:54 PM
Then you definitely have a voice-curcuit fault which you will need to report.
09-05-2021 3:19 PM
Ok well cant do anything for 18 hours while the phone charges, is depleted and charged again Oo
09-05-2021 3:26 PM
You said in post #5 'I tried to dial out and nothing happened'. In that case, a different handset set-up will make no difference. If you have a mobile phone, I would suggest ringing in on 0800 432 0200 as early as possible tomorrow.
09-05-2021 3:32 PM
Of course but one of the first things in their checklist is test your phone etc and my phones are old. I need to narrow down the possible problems as much as possible.
09-05-2021 3:33 PM
OK.
19-05-2021 5:09 PM
Far easier / much more sensible to go get a cheap corded phone for sub £5 - or borrow one!
Old cordless phone could generate their own noise, which could be mistaken for noise on the line.
Having a working corded phone is a highly valuable diagnostic tool, worth far more than it costs in situations such as this.
