Constant Internet Disconnections
sully48
Happens in the evening not the daytime , Internet hangs then restarts after a few min.
Any help appreciated
valart
Re: Constant Internet Disconnections
My connections drops once a week always in the evening and it quickly connects I suppose you can call it a automatic bootup for the router I suppse you can call it Ground Hog week,it is not a problem but just odd.
thesawdust
@sully48 - how often does it drop? Daily/weekly?
Your line is dropping quite severely :
<img src="http://community.plus.net/visualradius/generated/image1385035268118.png"/>
Have you changed anything recently, is there any noise/interference on your phone line?
sully48
Thanks for the reply , as far as im aware nothing has been changed , my PC is connected via Ethernet and others wireless nothing new has been added to the setup.
I might dig out some old filters and try these if that could possibly cause the issue?
Plusnet Staff
Plusnet Staff
Fixes: 5
It would be worth a try and that could potentially be the cause. If you could try alternative microfilters, that'd be great.
Chris Pettitt
Cloud Environments Engineer
