Constant IP conflicts - Technicolor 582N
shure
I've just been with Plusnet a couple of weeks now and one of the issues I am getting on a regular basis is constant IP conflicts, meaning I have to reset the router several times a day sometimes.  I could assign static IPs with my old Netgear DG834PN but can't see an obvious way to do that with the Technicolor due to its comparatively limited user configuration possibilities.  Any suggestions?
Fixes: 24
Re: Constant IP conflicts - Technicolor 582N
Set static IP addresses on your devices.
Fixes: 5
Conflicts with that?
Kelly Dorset
Broadband Service Manager
shure
thanks for your reply ReedRichards.  I thought it had to be done through the router itself but I'll give it a go Smiley
shure
Quote from: Kelly
sorry, don't understand your question?
Fixes: 5
What is your IP address conflicting with?  You'll either have a static IP from us, or we'll be allocating you a dynamic IP which shouldn't be conflicting with anything?
Kelly Dorset
Click on Home Network and then Devices ( I think)
Select the device and you can assign a static address.
The DHCP range is from .64 to .252 if you want to assign you own addresses start from .1
What is the IP address you are getting a conflict with?
Dan.
Fixes: 162
I think he means internal address conflicts on the LAN, rather than external WAN ones.
 Chris Parr
 Plusnet Staff
shure
wow, you guys are fast.  Only went to get a cup of tea!
Chris is correct - I'm talking about LAN conflicts.  I have 4 mobile phones, a (fixed connection) PC, laptop, PS Vita, PS3, Xbox and a DS connected, and I get a couple of conflict messages on any one of the above at various times of the day.
I'll try and set the addresses on each piece of kit, which is a bit of a ball ache but hey-ho.  How do you see the DHCP range on this?
shure
Quote from: Grumpy
Dan.
many thanks for your reply.  Only saw it after I posted my second question
shure
Did it.  Thanks to everybody for your help
