Constant Disconnecting
AlanH1
Heya,
I had an issue a few months ago where my internet would drop a several times a night, the red light would flash on the router and would eventually reconnect, then disconnect, rinse and repeat.
An engineer came out, fixed some of the wiring and I got a new router which appeared to fix it.
Then Friday night the disconnects started again and have been happening ever since.
Any ideas?
1 REPLY
Fixes: 181
Re: Constant Disconnecting
Sorry to hear you're having issues with your service.
Our tests aren't showing any causes for this but if the drops continue I'd recommend raising a fault here
 Matthew Wheeler
