Constant Disconnecting
- Re: Constant Disconnecting
17-12-2017 12:41 PM
Heya,
I had an issue a few months ago where my internet would drop a several times a night, the red light would flash on the router and would eventually reconnect, then disconnect, rinse and repeat.
An engineer came out, fixed some of the wiring and I got a new router which appeared to fix it.
Then Friday night the disconnects started again and have been happening ever since.
Any ideas?
Message 1 of 2
(417 Views)
1 REPLY 1
19-12-2017 9:52 AM
Sorry to hear you're having issues with your service.
Our tests aren't showing any causes for this but if the drops continue I'd recommend raising a fault here
Message 2 of 2
(342 Views)
