Constant Broadband Connection Dropouts
stevenwhit
Since early yesterday morning (15/7) I have had constant dropouts to my broadband connection - every 4-5 minutes that last 10 or so seconds, the connection light on the router doesn't go out (Netgear DG834Gv2) and it comes back automatically, but it is very frustrating.  I have tried the usual things - rebooting router etc, phone line seems ok, all exterior wiring and outlet were replaced last year by BT after a major fault on the exterior wiring.   But as of this morning 16/7 the problem is still there.
Gel
Seasoned Pro
Fixes: 12
Re: Constant Broadband Connection Dropouts
stevenwhit
mmm do you mean these?  Had to google what you meant, this is what came up..  I have no idea what any of these mean though. Embarrassed
Fixes: 59
nothing obvious there - I suggest raising a dropping connection fault
https://faults.plus.net
but  I would suggest checking here first for the checks you should carry out https://www.plus.net/help/broadband/connection-troubleshooting/
stevenwhit
thanks, I started that online fault reporting early this morning, but stopped at the testing with a new microfilter - I dont have a spare so will have to get one.  Disconnections seem worse right now too. hmm Angry
Fixes: 30
Are you directly connected or via WiFi?
stevenwhit
Wifi - Netgear DG834Gv2 router
Fixes: 30
Your attachment earlier showed you were connected for over 29 hours, so worth going through the WiFi help pages,
Ideally download a WiFi analyser app and see what channels are least used and swap the router to one of those.
Fixes: 59
I didn't read it that way - you need to look at the WAN uptime which is 2 hr 48 mins
stevenwhit
I reset the router this morning and also tried connecting via ethernet - still constant dropouts every 5-6 minutes.   Anyone from plusnet that can look into this from here?  Have to send of for a new broadband filter to test that too as I dont have any spare..
Fixes: 254
Your connection is fairly intermittent over the past week.
Our tests aren't identifying the cause of that.
I've sent you a new microfilter now, free of charge, so that you can continue with your troubleshooting. If the connection drops persist, I'd recommend completing the the broadband troubleshooter as that'll raise a fault with us.
stevenwhit
Many thanks, I started the online trouble shooter but stopped at the point where it asks to try a new microfilter, will continue with a new one.
