Consistsent Drops over last week
FIXED- Subscribe to RSS Feed
- Re: Consistsent Drops over last week
11-06-2024 9:38 AM
I have drops when inbound calls are received on the line since the service was installed. Had BT out numerous times and the problem still remains:( I have two more identical lines to the house. Neither of which have this problem.
In the last week the Plusnet line drops several times a day now and is usually out for a good 5 mins each time as it sync's up. Working from home this makes it extremely frustrating. Whilst i appreciate this is not Plusnet and a local area fault. I would be grateful if we could look at the local cabinet for the crosstalk issue. This seems to imply a high resistance fault or maybe a rectified loop. Or even trees nudging the line.
Regardless, the severity and frequency of service loss has rapidly increased in the last week, and i would appreciate this being escalated to BT for fresh line diagnostics please.
Fixed! Go to the fix.
13-06-2024 4:32 PM
@ciscobandit sorry about taking forever to get back to you. The test is saying high resistance and wants to book another engineer. Not much we can do from our side without popping those guys out until it's fixed. Sorry about this.
13-06-2024 4:58 PM
Exactly what i was assuming. Is it possible to get an engineer booked please. Appreciate it's not Plusnet's fault it's a local fault presumably in the local cabinet or exchange.
15-06-2024 3:26 PM
15-06-2024 5:23 PM
Any day Monday to Thursday is fine as i work from home. I'd prefer an 8am to 1pm time please:)
16-06-2024 9:48 AM
19-06-2024 9:17 AM
Spoke to BT engineer and pointed them in right direction. The problem was a loop from the cabinet to the PCP, with the loop/crosstalk introducing the resistance and therefore fault. The BT engineers moved me to alternate pair on the path. And after some testing the resistance has gone, the line is considerably cleaner and does not drop when the line receives calls.
Thanks for listening and supporting, i look forward to a more stable service ![]()
20-06-2024 4:09 PM
I'm glad to hear this @ciscobandit any more issues please don't hesitate to get back in touch.
