Connection very flaky since yesterday morning, any ideas?
markmcguigan
Hey guys,
After having no issues at all with my connection yesterday morning things started acting up and have been the same since. At first I wondered if there was a problem with the line but then I noticed I seem to be getting repeated FIREWALL events plus last night the CHAP authentication was failing.
Woke up this morning and that seems to be OK but still getting these FIREWALL events that seem to be bringing down the link and the line doesn't look too great either. Any ideas?
Current Router Stats:
Uptime: 0 days, 0:00:36
DSL Type: ITU-T G.992.1
Bandwidth (Up/Down) [kbps/kbps]: 384 / 1.632
Data Transferred (Sent/Received) [MB/MB]: 4,13 / 16,24
Output Power (Up/Down) [dBm]: 12,5 / 19,8
Line Attenuation (Up/Down) [dB]: 20,5 / 33,5
SN Margin (Up/Down) [dB]: 6,0 / 12,0
Chipset Vendor ID (Local/Remote): BDCM / TSTC
Loss of Framing (Local/Remote): 845 / -
Loss of Signal (Local/Remote): 107 / -
Loss of Power (Local/Remote): 0 / -
Loss of Link (Remote): -
Error Seconds (Local/Remote): 1.661 / -
FEC Errors (Up/Down): 66 / 0
CRC Errors (Up/Down): 87 / 0
HEC Errors (Up/Down): -7 / 0 / 0
Router Event Logs
Many thanks for your time.
7 REPLIES 7
markmcguigan
Re: Connection very flaky since yesterday morning, any ideas?
Not sure if above gives whole picture as it seems now that the link is up and down like a yo-yo:
Uptime: 0 days, 0:00:38
Bandwidth (Up/Down) [kbps/kbps]: 640 / 2.080
Data Transferred (Sent/Received) [MB/MB]: 5,02 / 17,25
Line Attenuation (Up/Down) [dB]: 21,5 / 33,5
SN Margin (Up/Down) [dB]: 7,0 / 7,8
Loss of Framing (Local/Remote): 950 / -
Loss of Signal (Local/Remote): 123 / -
Error Seconds (Local/Remote): 1.851 / -
FEC Errors (Up/Down): 73 / 2.371
CRC Errors (Up/Down): 464 / 174
HEC Errors (Up/Down): -64 / 174 / 3.470
ejs
Aspiring Hero
Fixes: 25
I don't think the firewall entries have anything to do with the problem. Probably a line fault, or maybe something gone wrong in the exchange - you don't get more than 448k upload on 20CN ADSL1 unless you pay extra for Max Premium, yet your stats say 640. Here's the list of things to check before raising a fault: http://www.plus.net/support/broadband/bbfaults/adsl-connection-troubleshooting.shtml
adamwalker
Fixes: 221
@markmcguigan
You were definitely right to raise a fault, in fact I can see that our tests have picked up on a line issue so we should hopefully have some feedback on that for you soon.
 Adam Walker
markmcguigan
Brilliant thanks, just this minute got back online (albeit with a low IP Profile ATM). I surmised the fault was with the line and the BT Engineer has been out today to fix the fault.
dick:quote
adamwalker
Fixes: 221
I assume that's as a result of you asking them to come out for an issue to do with your phone service as I can't see that we've booked an engineer.
Keep us posted, we'll get on the case if there's any further problems with your connection.
Adam
 Adam Walker
markmcguigan
Yeah, I booked the BT engineer as the noise on the line was getting worse and worse. Everything seems stable now, just waiting for the IP profile to pick back up in the next few days and we should be as good as new Smiley
Many thanks Adam.
adamwalker
Fixes: 221
It's definitely looking better so far Smiley
<img src="http://ccgi.psmith12.plus.com/visradius/generated/image13723206055656.png"/>
 Adam Walker
