Connection speeds dropping lower and lower
- Re: Connection speeds dropping lower and lower
15-12-2015 5:22 PM
I have been with PlusNet for a couple of years and before that I had Virgin ADSL (having moved to a new build home which had no Virgin cable).
Once I moved in I synced up at about 7.5Mbit, things went wonky, Virgin sent someone from BT Openworld who fixed things outside the property and things were great, solid connection.
I joined PlusNet and synced up at 6.8 - 7mbit. About 8 months ago this started to drop to around 6.5 and has progressed down to about 4.4, it has hit as low as 3.8 !
I have the same phone, tried new filters etc. Using master socket, linked with Ethernet cable, no viruses etc.
My neighbours suffered a similar problem, BT Openworld came yesterday and left and then came back having been to exchange and cabinet and now they are syncing up near 8000KBPS, they are on Sky. Sky engineer checked everything internally and all was sound.
Can anyone help me from Plusnet?
15-12-2015 5:34 PM
15-12-2015 8:23 PM
A warm welcome to the forum. That is a good start - the other information requested on the speed issues thread (link below) would be helpful please.
16-12-2015 10:33 AM
Loop Loss: 47.5
SNR Margin: 7.3
Speed: 443 5259
Mean Time Between Errors Downstream (Seconds): 76
16-12-2015 10:55 AM
@greenleader - also can you please check the phone line for noise. From the master socket, dial 17070 option 2 using a corded handset. It should be darned near silent.
16-12-2015 11:35 AM
Tonight I will try to run the check from the test socket, I did a speed test and checked sync as well a few months back and it was not much different.
When I was leaving work this morning my other neighbour had a BT open world engineer there and I asked what was going on. He said that while the exchange upgraded for fibre the speeds or "profiles" were turned down and never set back hence everyone running slower. I will ask her when I get home if she is syncing back up around 7 or not.
I was recently offered a new contract with PlusNet, which I have 14 days to cancel. They say that "Estimated line speed:
8Mb (This may vary between 5.5Mb and 12.5Mb)". I am a bit away from that, which is a bit sad considering the price of the line and the broadband have both increased. Realistically if my line is capped at 5MB then I wont ever get what is being suggest?
16-12-2015 11:53 AM
What might be nearer the truth is that when the FTTC upgrades were installed no additional capacity between the exchange and the rest of the web was installed, consequently the speed of DATA transfer has been impacted for everyone by the few receiving higher delivery speeds.
Setting that aside, your problem rather looks like one (initially) restricted to the home to the exchange network. It also looks like the BTOR darabase records for your line are wrong. If the line attenuation (loop loss) reported by Chris is correct your line is never going to SYNCH faster than 7Mbps.
Right now the attention needs to be on identifying the source of the very low MTBE figure on your line. Given your neighbour also has bb speed issues, there is the possibility of a shared cable fault.
16-12-2015 2:42 PM
dick:quote
16-12-2015 2:58 PM
When I am trying to get to connection Stats, does that mean I need to download the router stats program? Think I got it:
Uptime: 0 days, 0:04:19 DSL Type: ITU-T G.992.5
Bandwidth (Up/Down) [kbps/kbps]: 443 / 5,639
Data Transferred (Sent/Received) [MB/MB]: 3.91 / 11.07
Output Power (Up/Down) [dBm]: 12.8 / 0.0
Line Attenuation (Up/Down) [dB]: 26.3 / 47.5
SN Margin (Up/Down) [dB]: 23.9 / 6.4
System Vendor ID (Local/Remote): TMMB / ---- Chipset Vendor ID (Local/Remote): BDCM / IFTN
Loss of Link (Remote): -
Error Seconds (Local/Remote): 6 / 0
FEC Errors (Up/Down): 0 / 0
CRC Errors (Up/Down): 0 / 8
HEC Errors (Up/Down): 0 / 7 generateTasks()
Does that make any sense!?
16-12-2015 5:30 PM
No - routerstats will only be required if we need to dig deeper. That above is exactly what we need.
The one off stats look reasonably OK, however there is no indication of the connection time here - does your router report this? The stats are different (a little better) to those reported by Chris earlier in the day, implying a resynch. The synch speed is still a little lower than it could be, but not significantly out of line.
Can you please do the checks we outline earlier please?
16-12-2015 6:03 PM
I did the phone thing and listened, was that right? There was a very low buzz, maybe that was the phone?
What are the connection stats in the link? I think that's everything?
Thanks.
16-12-2015 6:19 PM
Was that buzz "50Hz hum" similar to that which can be heard with some electrical company?
Was the router plugged into the line when you heard that buzzing? Try unplugging the router and see if it is still there.
17-12-2015 8:34 AM
I do not have a corded phone. I will try it again when I get back home and see if no router makes a difference.
Thanks for the help.
17-12-2015 1:14 PM
