Connection speed dropped by 75%
- Connection speed dropped by 75%
17-12-2015 11:57 AM
Hi, could someone at support please look into my case? In the last few days my connection speed has dropped to around 4mbps, it's usually 16-17Mbps (i live very close to the exchange). Upload seems unaffected (around 1.1Mbps). All requested stats are below.
Noise margin: 6.5/9.1
Line attenuation: 5.9/13.5
BT Wholesale Broadband Performance Test
Download speed achieved during the test was - 3.59 Mbps
For your connection, the acceptable range of speeds is 4 Mbps-21 Mbps.
IP Profile for your line is - 17.82 Mbps
Upload speed achieved during the test was - 1.08Mbps
Upstream Rate IP profile on your line is - 0.83 Mbps
Estimated line speed:
Current line speed:
3.8 Mb
I'd greatly appreciate any help with this, very frustrated.
Current line speed:
3.8 Mb
Message 1 of 3
(703 Views)
2 REPLIES 2
Re: Connection speed dropped by 75%
17-12-2015 1:18 PM
Your line is pretty stable, although there have been a few disconnections today and yesterday:
This has caused the line profile to lower to 3800, causing the speeds you're seeing. However this has now increased again back to normal, so if you disconnect/reconnect once you should see an improvement.
Message 2 of 3
(394 Views)
17-12-2015 7:26 PM
Thanks Chris, as you said, seems fine now.
Message 3 of 3
(394 Views)
