Connection shows LIMITED
gprit
After my laptop goes into Sleep or Hibernate mode, when it wakes up the connection is always LIMITED.
I try and disconnect and then reconnect but usually this does not work.
I have to restart my laptop and then it connects ok.
This is really annoying - I tried removing a setting that enabled it to disconnect from the internet to save power, but no difference.
Don't think it is anything to do with the modem as a second laptop works fine.
Running under WIN8.
Any thoughts?
