Connection setting query
- Connection setting query
13-12-2015 4:28 PM
If this suggests I’m fairly clueless on this subject it’s because I am. Advice gratefully received.
Re: Connection setting query
14-12-2015 8:04 AM
You should be able to just change the connection setting on the Extreme to PPPoE and input your Plusnet details ( the same ones you presumably have already entered into the Tp Link.
As to the static IP, don't worry, the IP is allocated by the PPPoE connection. All that having a static IP means is that it will always allocate the same one.
14-12-2015 1:30 PM
14-12-2015 2:12 PM
I'm not sure where you mean ? in the Extreme ?
Quote Do I also have to change settings in System Preferences > Network?
TBH I'm not that familiar with the Extreme. You shouldn't need to change anything other than the WAN setting from DHCP to PPPoE
14-12-2015 3:52 PM
14-12-2015 5:00 PM
