Connection reset to 1mb?
- Connection reset to 1mb?
22-02-2008 12:05 AM
i've had adsl max now (runnin at around 7mb) for over well 6 months now, yet the last couple of days it's running at 1mb speeds. Adsl speedtests confimed this.
also when i go to Member Center > Connection settings > high speed broadband. It also states my service is 1000kbps.
I'm well within my usage limits. Currently connected to the thn-ag3 gateway and no faults have been reported at my exchange, i did however experience the delicious unable to connect period.
any ideas?
Re: Connection reset to 1mb?
22-02-2008 1:19 AM
Once the sync speed returns to normal (around the 7000kbps you mentioned) you should find the profile increases again in 3-5 days.
You should be able to get the connection stats (sync speeds/noise ratios/attenuations) from your router's web interface pages. Kitz's page here may help with this.
22-02-2008 11:20 AM
i'm not at home at the min to copy the connection stats from my router, i will do that when i get home.
22-02-2008 11:26 AM
You're currently synchronising at 8096Kbps.
However, at 20/02/2008 01:58:09 you had a sync event of 1152Kbps. Your profile should amend itself in the next day or so.
22-02-2008 5:07 PM
Line Mode G.dmt Line State Show Time
Latency Type Interleave Line Up Time Duration 01:15:17:31
Line Coding Trellis On Line Up Count 1
Statistics Downstream Upstream
Line Rate 8096 Kbps 448 Kbps
Attainable Line Rate 9824 Kbps 1292 Kbps
Noise Margin 8.8 dB 28.0 dB
Line Attenuation 0.0 dB 2.5 dB
Output Power 12.5 dBm 9.8 dBm
still getting 1mb.
any ideas?
22-02-2008 5:09 PM
22-02-2008 7:02 PM
my current router stats have dropped from it's original 8000kbps down to 2880kbps (i still get 900kbps naturally):
Line Rate 2880 Kbps 448 Kbps
Attainable Line Rate 3232 Kbps 1208 Kbps
Noise Margin 20.8 dB 24.0 dB
Output Power 12.2 dBm 9.8 dBm
24-02-2008 4:54 PM
just another query, should i expect the line speed to increase gradually or in an instant?
my connection is actually only averaging 800kbps now, and i've experienced no increase at all. I realize there is a certain degree of patience in this, but i get the feeling that i am waiting for something that isn't the cause of the problem.
24-02-2008 8:30 PM
I suggest having a look at Jameseh's blog broadband-speed-faults-how-to-diagnose.
26-02-2008 2:39 PM
thanks to all that helped.
