Connection randomly drops
- Re: Connection randomly drops
25-06-2013 12:22 AM
Hi, my fibre broadband has disconnected a few times over the last couple of days I think it usually happens around midnight? I reset the routers and eventually it comes back on but for a while it gives the Concentrator not reachable error. Bit annoying
Message 1 of 2
(550 Views)
1 REPLY 1
25-06-2013 3:45 AM
When the connection drops out like that, you might need to power the router off for 15 minutes before powering back up again, It's to do with some kind of time out AFAIK.
Hope this helps,
Matt
Hope this helps,
Matt
Message 2 of 2
(254 Views)
