Connection password reminder
- Re: Connection password reminder
05-01-2011 7:36 PM
Is it possible to get a reminder of the password used for connection (for the router)? I havent touched my router in a few years and getting FTTC tomorrow so new router will be going in with it. Am I right in thinking its the same password as you use to log into the Portal? (obviously different username which I have from the connection settings page)
Message 1 of 3
(2,401 Views)
2 REPLIES 2
05-01-2011 7:42 PM
Yes it is the same one as used for the portal
Message 2 of 3
(372 Views)
05-01-2011 7:45 PM
Brilliant - thanks for the reply, had a feeling it was from the last time I replaced the router. Hope the change to FTTC goes as smoothly
Message 3 of 3
(372 Views)
