Connection multiple disconnections
- Connection multiple disconnections
16-09-2013 8:47 PM
Hello all
My connection after being very stable is showing signs of strain with multiple disconnects over a short period of time.
Check here
http://www.thinkbroadband.com/ping/share/0664c0b16324aa4a00a0791bb10da399-16-09-2013.html
Could anyone offer any advice?
Connection details here
DSL Connection
Link Information
Uptime: 0 days, 0:38:38
DSL Type: ITU-T G.992.5
Bandwidth (Up/Down) [kbps/kbps]: 1.259 / 15.916
Data Transferred (Sent/Received) [MB/GB]: 859,21 / 1,83
Output Power (Up/Down) [dBm]: 12,6 / 0,0
Line Attenuation (Up/Down) [dB]: 17,1 / 30,5
SN Margin (Up/Down) [dB]: 5,2 / 3,9
Loss of Framing (Local/Remote): 24 / 0
Loss of Signal (Local/Remote): 4 / 0
Loss of Link (Remote): -
Error Seconds (Local/Remote): 4.651 / 6
FEC Errors (Up/Down): 0 / 0
CRC Errors (Up/Down): 43 / 55
HEC Errors (Up/Down): 68 / 133
Check here
DSL Connection
Link Information
Message 1 of 2
(513 Views)
1 REPLY 1
Re: Connection multiple disconnections
17-09-2013 10:03 AM
Certainly is intermittent:
<img src="http://community.plus.net/visualradius/generated/image13794085337935.png"/>
I'd definitely recommend running through the faults wizard (http://faults.plus.net) - if the checks that takes you through don't fix the issue it'll be a line fault and the wizard will raise a ticket through to our team.
Message 2 of 2
(269 Views)
