Connection lost ... for no reason ?
St3
Aspiring Champion
Fixes: 5
Anyone else loose connection from 02.37am too 02.50am ?
I noticed the websites offline, did something go wrong with the net too ?
15 REPLIES 15
DaveyH
Champion
Fixes: 12
Re: Connection lost ... for no reason ?
Yep. Dropped several times in the last half hour or so.
Edit - now getting lots of buffering on YT...
TORPC
Mine has been running slow for the past 40(ish) mins or so
Checking router stats as no sign of dropped connection
No drop however, the sync seems low
[code= HG533 Router GUI]  ADSL (Sync) Summary
  System uptime: 40:28:38
  Modem ADSL (Sync) uptime: 38:48:36
  Interleaving: On
  ADSL mode: ADSL2+
  ADSL settings: PVC:0/38
  ADSL line speed (kbps): up 612 down 7906
  Line attentuation (dB): up 30.1 down 53.0
  SN margin (dB): up 5.6 down 7.2
  Total errors seconds: 69[/code]
ReedRichards
Seasoned Pro
Fixes: 25
Quote from: TORPC
You cannot get a change in sync speed without the connection being dropped and that happened 40 hours and 28 minutes prior to posting.
GeordieMark
Yep I had a drop from around 2:45 to 2:51, was wondering why it dropped, seems like it wasn't a line issue then...
St3
Aspiring Champion
Fixes: 5
I think I found the reason why, I don't personally use twitter so im late in seeing this news about possible downtime.
https://twitter.com/plusnet/status/491247140966916098
http://usertools.plus.net/status/archive/1405955459.htm?utm_source=twitterfeed&utm_medium=twitter
According to this expect more possible downtime, the good thing is its happening over night.. altho that might upset someone Tongue But I guess this work needs to be done!
GeordieMark
Ah yes that would make sense, 22nd in Newcastle, maybe I should keep an eye out for this things  Grin But as above it didn't affect me being at almost 3am anyway  Smiley
Pettitto
Fixes: 5
You can sign up to receive these alerts here: http://usertools.plus.net/status/email.php Smiley
GeordieMark
Cheers Chris, that's exactly what I was looking for Smiley
chrcoluk
just had a ppp outage, whats going on plusnet?
Pettitto
Fixes: 5
Is the connection back up now?
GeordieMark
No further outages here.
chrcoluk
yes you can see the time on my tbb graph in my sig.
it initially went down and came back up but with a ip that wasn't routing.  (I have static ip, this ip was in diff netblock).
I then went away for 10 minutes or so, did something else, came back and it came back online.
AndyH
Are the blips on the users graph are network issue or graphing issue? http://www.plus.net/support/service/network_performance/broadband_bandwidth_usage.shtml
dave
Fixes: 4
Looks like some customers got disconnected with the BTW network about midday, I can see nearly half the Plusnet customers on chrcoluk's BRAS dropped, there may have been others.
AndyH - the blips are a graphing glitches, although that graph doesn't look right as there was some maintenance this morning that doesn't seem to appear on it.
Dave Tomlinson
Plusnet Technology
