Connection issues
Tim8191
Connection issues
Hi this evening on experiencing connections issues but not on all of my devices, so my phone and ps5 can't connect yet my tv and firestick are connected. Any idea? I've resent the hub and unplugged the wires. Thanks
9 REPLIES 9
jwsg
Re: Connection issues
Nikib72
Have you had any news on your Internet been down, can I ask where abouts u r from plz xx I'm in Sheffield S6 area and I have nothing, not even my sky glass TV as it runs on Internet
bobbob455
I’m north of Leeds, same here, all broadband is down
bearddude
According to a recorded message when you phone Plusnet support, they currently have widespread broadband connectivity issues. I’m in Hertfordshire and my TVs and security cameras have internet connectivity but phones and laptops do not. Very odd…
howardl
Down here in Oxford.
stephenw10
If, as reported, it's a problem with Plusnet's DNS servers then anything that has hard-coded DNS servers (e.g. Android TV) or resolves directly by default (e.g. pfSense) would not be affected.
pittdj70
Plusnet's DNS is an issue here, using Cloudfare helps.
redsox9
Fixes: 4
Unable to access the Internet I found that the DNS settings I had set manually on my router had disappeared. I simply re-entered them and voila!
Mav
Fixes: 518
Forum Moderator and Customer
