Connection issues
rpucyk
Connection issues
Hi guys, for the last couple of days broadband was up and down good few times.
Had this problem before and it looks like it keeps coming back every few months.
SNR reset usually helps but maybe it is worth further investigation as its getting ennoying to deal with the same issue every so often :/
Plugged into test socket, ethernet cable from router to PC , no noises in line.
All stats below.
Also noticed a big drop on upload speeds....again.
Thanks in advance.
1 REPLY
Fixes: 152
Re: Connection issues
It doesn't look pretty from here.
I'd recommend raising it here https://faults.plus.net so we can have a look.
 Matthew Wheeler
