Connection issues
- Connection issues
Connection issues
05-05-2015 11:40 PM
For a good couple of weeks now but far more pronouncedly in the last 5 ish days my connection has dropped a lot. Please see router status report below. I play poker online for cash and the conx issues are affecting this now. Before the last 3-4 days conx to GUI clients was stable during disconx while webpages and at times even router homepage were inaccessible - at those times broadband light stayed steady blue but has been going orange with random regularity recently though I am also aware of heavy rain through Carlisle recently thus I wonder if the exchange may be affected.
ADSL line status
Connection information
Line state Connected
Connection time 0 days, 0:04:07
Downstream 9,740 Kbps
Upstream 1,128 Kbps
ADSL settings
VPI/VCI 0/38
Type PPPoA
Modulation ITU-T G.992.5
Latency type Interleaved
Noise margin (Down/Up) 3.9 dB / 6.4 dB
Line attenuation (Down/Up) 36.0 dB / 19.3 dB
Output power (Down/Up) 0.0 dBm / 13.1 dBm
Loss of Framing (Local) 0
Loss of Signal (Local) 0
Loss of Power (Local) 0
FEC Errors (Down/Up) 665355 / 0
CRC Errors (Down/Up) 51 / N/A
HEC Errors (Down/Up) N/A / 10
Error Seconds (Local) 1388
ADSL line status
Upstream 1,128 Kbps
ADSL settings
VPI/VCI 0/38
Type PPPoA
Message 1 of 5
(1,145 Views)
4 REPLIES 4
Re: Connection issues
06-05-2015 12:01 AM
I suggest reporting a 'dropping connection' fault using the troubleshooter at http://faults.plus.net.
This will run some basic checks and pass the problem to the Faults Team for more detailed investigation.
David
Message 2 of 5
(500 Views)
06-05-2015 1:37 PM
Message 3 of 5
(500 Views)
09-05-2015 2:17 PM
Probably a good idea to start with the basics.
Can you hear/have you heard any crackling or other noises on the line when using the phone? Have you had any problems with incoming or outgoing calls?
As you've used the troubleshooter I expect it would have mentioned about the Test Socket etc - did you try that assuming you have a Master Socket like the one on the left?
Message 4 of 5
(500 Views)
11-05-2015 3:41 PM
Message 5 of 5
(500 Views)
