Connection issues
- Connection issues
Connection issues
12-03-2014 6:49 PM
I'm finding it impossible to connect to some sites. I've tried disconnecting the router but no luck.
I tried tracerouting www.linx.net by telnetting into to the tg582n. I could ping www.plus.net at this time, but not portal.plus.net.
I get the same result from the wired and wireless devices in the house. Router in master socket (which is a dsl faceplate type) with no extensions connected.
12/03/2012 18:20
: traceroute addr=198.18.1.38
ttl=1 195.166.128.185 24775 us 27064 us 22043 us
ttl=2 212.159.2.172 22866 us 21838 us 22247 us
ttl=3 * * *
ttl=4 * *
Do you want to continue traceroute? (y/n) :n
12/03/2012 18:24
ttl=1 195.166.128.195 33521 us 22009 us 21590 us
ttl=2 212.159.2.144 22435 us 21917 us 21676 us
ttl=3 * * *
The connection has been unreliable for some time now but has resolved with time. I'm getting fed up and thinking of leaving.
12/03/2012 18:20
ttl=3 * * *
ttl=4 * *
12/03/2012 18:24
ttl=3 * * *
Message 1 of 2
(411 Views)
1 REPLY 1
Re: Connection issues
12-03-2014 11:36 PM
Have you raised a fault with us at all?
It's probably worth getting our Faults Team to take a look, if it's an external issue, we can get that resolved for you. You can raise a fault online at http://faults.plus.net
Message 2 of 2
(226 Views)
