Connection issues
- Connection issues
- « Previous
- 1
- 2
- Next »
Re: Connection issues
04-09-2013 5:15 PM
04-09-2013 5:32 PM
Many thanks.
05-09-2013 5:08 PM
Estimated line speed:
Current line speed:
7.15 Mb
BT test
Download Speed
1.48 Mbps
Download speedachieved during the test was - 1.48 Mbps
For your connection, the acceptable range of speeds is 0.8 Mbps-2 Mbps.
Additional Information:
Your DSL Connection Rate :1.95 Mbps(DOWN-STREAM), 0.7 Mbps(UP-STREAM)
IP Profile for your line is - 1.5 Mbps
05-09-2013 5:18 PM
Hope that helps.
07-09-2013 10:58 AM
UpStream Connection Speed 704 kbps
BT test
Download Speed
1.22 Mbps
0 Mbps 2 Mbps
Max Achievable Speed
Download speedachieved during the test was - 1.22 Mbps
Your DSL Connection Rate :1.54 Mbps(DOWN-STREAM), 0.7 Mbps(UP-STREAM)
IP Profile for your line is - 1.25 Mbps
Profile is still dropping.
I'll be honest every time I've gone through the faults ticket I've ended up with more problems afterwards so i would rather not bother or just cancel contract,this issue seems to happen every 2-3 months, sometimes it just goes away after a day other times it just keeps dropping for days.
I've brought over 4 routers (as that is what i am told is the problem) and many filters now and won't be doing it any more.
Thanks.
09-09-2013 10:26 AM
09-09-2013 10:49 AM
If i switch to the test socket it will still be the same.
09-09-2013 1:57 PM
09-09-2013 2:54 PM
09-09-2013 3:24 PM
It may be that a fault needs rasining, I'm happy to oversee this if you're not overly confident about going down the fault route.
09-09-2013 3:55 PM
Although my speed has now gone to 900kb
09-09-2013 4:55 PM
0.97 Mbps
0 Mbps 1 Mbps
Download speedachieved during the test was - 0.97 Mbps
For your connection, the acceptable range of speeds is 0.4 Mbps-1 Mbps.
Your DSL Connection Rate :1.57 Mbps(DOWN-STREAM), 0.7 Mbps(UP-STREAM)
IP Profile for your line is - 1 Mbps
14-09-2013 6:19 PM
16-09-2013 2:10 PM
I'm happy to take a look over things if you still require.
- « Previous
- 1
- 2
- Next »
