Connection issue
SamNH4
Connection issue
I have solid blue light but no internet. Tried everything that I could think of. Reset, unplug, check cables, check with lan cable, disconnect the connection from advance settings of router and reconnecting. I also tried to reset the settings. The router connection check says I’m connected but it doesn’t send or receive.
