Connection is great!! But just a few things niggling me..
- Connection is great!! But just a few things niggli...
18-11-2009 6:56 AM
C:\Users\Ade>tracert bbc.co.uk
Tracing route to bbc.co.uk [212.58.224.138]
over a maximum of 30 hops:
1 2 ms 1 ms 1 ms www.routerlogin.com [192.168.0.1]
2 23 ms 23 ms 22 ms lo0-plusnet.pcl-ag04.plus.net [195.166.128.134]
3 22 ms 20 ms 21 ms gi1-6-604.pcl-gw02.plus.net [84.92.0.229]
4 21 ms 22 ms 22 ms te2-2.thn-gw2.plus.net [212.159.0.190]
5 23 ms 21 ms 22 ms rt0.thdo.bbc.co.uk [212.58.239.25]
6 21 ms 21 ms 22 ms 212.58.238.149
7 22 ms 21 ms 21 ms virtual-vip.thdo.bbc.co.uk [212.58.224.138]
Trace complete.
This is the most stable connection i've ever had. (im on gaming package btw) I was just wondering is there any possible way to increase upload speed? (I used to have 832k+ upstream on idnet) Also my download seems capped at 6.5meg, even though I know my line can take over 7.5, is there a reason why its capped at the 6.5? Just wondering.
Thanks.
Andy
Re: Connection is great!! But just a few things niggling me..
18-11-2009 9:16 AM
As for your line speed if you post your router stats people will be able to offer any ideas, one thought is were you on ADSL2 idnet?
18-11-2009 6:18 PM
Sadly I can't get ADSL2 no, im on 20cn. My Exchange is 'MYPIC' on IDNET I was using their Home SuperMax package linked here: http://www.idnet.net/solutions/home/broadband/default-adsl.jsp
So I know my line can take more, just wondering if Plusnet can upgrade it even further?
Andy.
18-11-2009 6:21 PM
Quote from: adiewoo You can increase your upload by getting the max premium which also gives you elevated priority across the BT network too.
Sorry as for Router stats, im on the Netgear DG834G
Modem
ADSL Firmware Version 7.03.01.66
Modem Status Connected
DownStream Connection Speed 8128 kbps
UpStream Connection Speed 448 kbps
VPI 0
VCI 38
System Up Time 48:01:08
Port Status TxPkts RxPkts Collisions Tx B/s Rx B/s Up Time
WAN PPPoA 3475693 3552166 0 2692 8430 47:52:40
LAN 10M/100M 2878420 2932692 0 3094 2621 48:01:04
WLAN 11M/54M 959545 652838 0 5737 412 48:00:53
ADSL Link Downstream Upstream
Connection Speed 8128 kbps 448 kbps
Line Attenuation 9 db 1.5 db
Noise Margin 3 db 25 db
18-11-2009 6:25 PM
18-11-2009 9:46 PM
Welcome to PN and the Forum. I'm guessing you're migrated in, so your line shouldn't be in a 10 day training period.
With those stats I'm guessing that you may have a flat above the exchange
Run the BT speedtester http://www.speedtester.bt.com/ to see what your BT profile is, and check at the member centre (login required) what your Data/Line rate is there https://portal.plus.net/my.html?action=data_transfer_speed . They should both be 7150. This is the maximum DS speed on an ADSL package.
As adiewoo has mentioned there is Max.premium which is £7.83 pm. extra.
see http://www.plus.net/support/broadband/products/faqs_and_guides/max_premium.shtml
I believe there is a one off charge of £14.99 to add this, and the same charge if later you want to remove it.
However, your exchange VP status is red at the moment http://usertools.plus.net/exchanges/?exchange=Pickering&exact=1999&plugin=vp so you are going to get throughput issues at peak times compounded by the current Network issue, so you may want to hold off on that (unless desperate) until both are fixed.
HTH, I'm sure someone from the PN Comms team will be along tomorrow to confirm that I've given you the right information.
19-11-2009 5:35 AM
Just ordered this upgrade, I never even knew about it until these forums. Thought I was on the best package I could get already!
It says it will be added to my account within a day, yet the question average answer time was about 65 hours, which is right ?
I live about 150m in a straight line from my exchange so pretty close yes. The BT test site requires a Service ID? Which I don't have so can't run the test.
Thanks for the help
19-11-2009 5:38 AM
19-11-2009 9:58 AM
19-11-2009 10:02 AM
19-11-2009 10:14 AM
19-11-2009 10:49 AM
19-11-2009 11:13 AM
19-11-2009 11:16 AM
19-11-2009 11:19 AM
