Connection has been terrible past month
rhann2015
Moved into new build house end of july and wated until september for bt to put lines in. When it all finnaly got installed i was getting about 7mb connection now i barely get over 2mb
https://postimg.org/image/kt86wm1t9/
https://postimg.org/image/4no8sxgr3/
I know they are tested on wifi but wired is pretty much same. I have already been on chat last week they said my profile is 4mb download
rhann2015
Re: Connection has been terrible past month
Your Plusnet adviser may ask you for the following information:
1 - Product name: Plusnet Router
2 - Serial number:
3 - Firmware version: 7.273.1_F2704N_Plusnet
4 - Board version: F@ST2704N
5 - Mode ADSL
6 - Uptime: 12 days 15:34:08
7 - Data rate: 952/4791
8 - Maximum data rate: 956/5020
9 - Noise margin: 6.1/12.4
10 - Line attenuation: 26.7/49.0
12 - Data sent/received: 1.8G/2.4G
20 - Broadband username: **********
21 - Wi-Fi network/SSID: Fraggle Rock
22 - Wi-Fi connections: Enable(802.11 b/g/n(up to 144 Mb/s))20 MHz WPS enabled
23 - Wi-Fi security: WPA2
24 - Wi-Fi channel: 6
25 - Firewall: Default
26 - MAC Address: 44:e9:dd:3b:a3:91
27 - Software variant Version 1.0
28 - Boot loader: 7.273.1
rhann2015
From my router stats can anyone see anything wrong
Fixes: 184
Apologies to the delayed response.
Testing your connection isn't indicating any obvious problems, the sync speeds aren't as low as I'd expect from the speed tests you're posting.
  Upstream DSL Link Information Downstream DSL Link Information
Loop Loss: 26.5 49.0
SNR Margin: 6.0 10.3
Errored Seconds: 0 48
HEC Errors: 0
Cell Count: 2096521 15598960
Speed: 967 5263
As a first step, if you haven't already, please could you go through our troubleshooting guide here: https://www.plus.net/help/broadband/connection-troubleshooting/
If you continue to experience the same low speeds following this, please could you run a wired speed test at http://speedtest.btwholesale.com/ and then continuing on to the further diagnostics option, as this will store the results on our suppliers systems.
After running the requested speed test, please raise a fault at http://faults.plus.net so we can investigate further.
 Harry Beesley
