Connection graphs
cbcadmin
Connection graphs
Do Plusnet still supply connection graphs?
I think this is/was one :-
http://ccgi.psmith12.plus.com/visradius/generated/image13293861531760.png
Keef - Sheerness Kent UK - Plusnet via Technicolor TG582N
Previously - Sky, EE, New Call Telecom/Fuelbroadband, Plusnet, Virgin/NTL/Bell Cable, Crosswinds, IC24, FreeOnlineNet, X-Stream, Totalise, Freeserve, Force9, TescoNet, AOL, Freenetname, Pipex, E7
Fixes: 21
Re: Connection graphs
That link no longer goes to a graph. If it's a Visual Radius graph you are after, then a Plusnet CRT rep can usually provide a current one but they are only usually available for about a month.
cbcadmin
I'm aware the link no longer works, but unsure why. Perhaps it is down to your last sentence i.e. they are only available for a month. Or is that they are only requestable for a month?
Anyway is there a Plusnet Cathode Ray Tube Rep that can help please?
Fixes: 21
To be a bit clearer, they only remain visible for about a month. I don't know how soon that a Customer Relations Team rep can get to you, I know they are up to their eyeballs at present (and they are only around in office type hours) often until 8pm..
cbcadmin
That explains why the example I posted isn't visible, as it is a few years old. Wink
Yes, I am sure the staff are busy. No doubt their numbers have been cut as well as their hours. Sad
