Connection generally great, but one small issue getting annoying
markpwindle
Basically my connection is quick, as far as I can tell stable and all in all i'm very happy compared to my old Sky connection.
I appear to be having one small issue though, which i'm not sure whether you will be able with or not as there's a possibility it's not a line issue, but I just want to check. Basically usually once a day the router loses it's network connection. A reboot always fixes it instantly, but it is beginning to get a little anoying. My current router is a Netgear DGND 3300 and I say current as I previously previously was using a Belkin N+ Router which didn't have this issue (that's why i'm assuming you can't help) though this had it's own set issues. Note that I am certian it is not the PC as it happens to all deices connected to it.
I was just wondering if there anything that Plusnet would do daily that could cause this, or any other ideas?
Thanks for your help.
