Connection from Asus Tablet
bravo
My Mini IPod connects to the wireless with no problem.
My wife's Asus Tablet tells me it is receiving an excellent signal but when I try to connect it fails and sometimes comes up with the message
'Avoided poor internet connection'
Can anyone help please?
One suggestion I explored was to try turning off my virus checker (McAfee).  Does this require it to be uninstalled?
Re: Connection from Asus Tablet
Hi bravo,
Have you tried a factory reset of your Asus tablet and then tried to connect again?
anniesboy
I experienced exactly what you describe when I was on holiday in French hotels.
It was nothing more than poor wifi signal,the tablet showed good connection but clearly was not good enough.
I would get close to your router and try again.
bravo
Thanks Anniesboy but still no connection next to router despite 'Excellent' signal strength.
Thanks to Chris a full restart did the trick and connected immediately.
