Connection drops when using wireless
- Connection drops when using wireless
07-08-2011 8:19 PM
Hi all
I've just reveived a Thomson TG585v8 from plusnet. Works absolutely fine when connected via standard etherner connection to my PC. Works fine when connected via ethernet to my laptop. When I connect wirelessly from the laptop its fine for a few seconds, then the router looses everything except power (so ethernet, wireless, broadband and internet). It then takes ages to pick itself back up.
Any ideas what to do?
David
David
Message 1 of 3
(1,153 Views)
2 REPLIES 2
Re: Connection drops when using wireless
07-08-2011 10:25 PM
I'm pretty sure I remember a very similar problem coming up on these forums recently, but I cannot find the thread, unfortunately. Hopefully I'm not imagining this and someone with a better memory will come along later.
Message 2 of 3
(461 Views)
07-08-2011 10:44 PM
I found the thread I was thinking of: http://community.plus.net/forum/index.php/topic,96921.0.html
This is the solution (of sorts) quoted in that thread http://www.intel.com/support/wireless/wlan/sb/cs-006205.htm
Edit: But nobody posted to say that they got the "solution" to work in this instance.
Message 3 of 3
(461 Views)
