Connection drops out regularly around midnight
ChrisEyre
I've noticed for quite a while now that my connection drops out several times around midnight to 1pm. It usually last for a few minutes and then reconnects. Is there a reason for this?
2 REPLIES 2
nanotm
Re: Connection drops out regularly around midnight
its possible your dropping due to network maint, have a look on the status page
http://www.plus.net/supportpages.html?a=2&?helpheader=servicestatus
orbrey
Looks like it's dropping more than that, but only started last night - might be maintenance but if it goes on more than a couple of days I'd say it'd be worth raising a fault anyway:
<img src="http://community.plus.net/visualradius/generated/image13726811766189.png"/>
You can raise it to us at http://faults.plus.net - that'll take you through a few checks but once it's done it'll go through to our faults team and they'll sort it for you.
