Connection dropping
- Connection dropping
Connection dropping
05-09-2009 5:12 PM
I have a fault ticket raised with Plusnet (29903931) about a failing connection, they have made their necessary checks through the fault finder and tell me there isn't a problem with the line that they can find.
Being intermittent I fully understand the difficulty, This fault started with just an occasional drop and over 2 or 3 months has now reached the point where it is a real pain.
I am currently plugged into the test socket through a brand new filter with all phones etc dis-connected and I am currently enjoying a good connection although earlier with the same set up as now I experienced drops and the router had difficulty reconnecting.
My suspicion is that the router, a Plusnet supplied BT Voyager 210, is starting to give up the ghost even though it's only 18 months or so old and has worked perfectly until 3 months ago!
To make a long story shorter, can anyone suggest if these stats from the Diagnostic test indicate a failing router and if so what router would you recommend?
Thanks for any help you can give.
Pete
Re: Connection dropping
05-09-2009 5:21 PM
05-09-2009 5:31 PM
I am connecting through the ethernet socket.
It has just dropped again and I took these stats through Kitz website once it came back on, do they help?
Thanks for the quick reply.
Pete
Im about to watch the football so wont be available for a couple of hours.
05-09-2009 5:37 PM
If you don't have a spare router you can borrow I suggest responding to the fault ticket asking if Plusnet can lend you a Thompson router to check. Previous posts by Jameseh indicates that this isn't usually a problewm.
05-09-2009 6:30 PM
Given that with my level of my expertise I didn't realise my stats were wonderful, Im grateful for your response.
I recall that when I joined plusnet about 18 months ago there was some debate about the longevity of the Voyager 210 so I have been half expecting this day ever since, given that, I will buy myself a new router and hopefully solve the problem........until next time!!
I am considering the Netgear DG 834G, or one of the Belkin models, any advice would be welcome.
Thanks again
Pete
05-09-2009 6:45 PM
Personally I like the Netgear DG834G but I don;t know about the latest version.
I do have a question though - do you want wireless as you presently aren't using it
If you do go for the DG834G this seems a very good price http://www.dslsource.co.uk/details.aspx?idProduct=1466
05-09-2009 8:45 PM
I dont really want wireless, is the Netgear DG834G only wireless or does it cater for both?
My reasoning is that not being very computer savvy I try to avoid anything that may turn out to be problematical.
Thanks for your time and the link.
Pete
05-09-2009 9:40 PM
However going non wireless there are a number of cheaper options such as the Thonpson Speedtouch range but in my opinion the quality is not as good as the Netgear and with the DG834 I would prefer the v4 to the v5 as it has the Broadcom chipset. I suspect the one at dslsource is the v5 unit
You may well get some more options from other posters
05-09-2009 10:01 PM
I checked out the dslsource site and your right, it is the v5 unit, I will check around for a v4 version so thanks again for your help and advice, I really appreciate it.
Im not too keen on Thompson equipment ever since I went through two Freeview boxes in less than 5 months, so I wont be going down that road again!
Pete
06-09-2009 9:31 AM
06-09-2009 11:52 AM
I think Im going to follow Old Jims link and get the v4 Netgear this afternoon.
Thanks agin
Pete
06-09-2009 2:11 PM
06-09-2009 2:53 PM
My local shop has said they will lend me a used router to check out the problem, but I am then morally bound to buy the Zyxel from them, and in view of what you have just told me I wouldn't have any concerns about doing that now, even though it will cost a few pounds more the little local guys need supporting.
So thanks to you and Jim for all the excellent advice.
Pete
06-09-2009 3:29 PM
09-09-2009 12:50 PM
I bought a new router and connected it Tuesday afternoon, so far it has worked perfectly apart from the DSL light blinking out for just a second mid morning, but Im guessing this isn't too unusual.
So thats about 20 hours whereas with the old router I couldn't get 20 minutes without losing connection badly.
Still have my fingers crossed!!
BTW I bought the ZyXEL router from my small local shop.
Pete
