Connection dropping
MikeKilo92
Connection dropping
I had a problem with Download speeds. An engineer came out to the green box and the issue with Download speeds was resolved. Immediately after I now have issues with the connection disconnecting. It happens all day everyday every 2-3 minutes. The hub will flash the orange light the connection will drop and it will automatically reconnect itself. It just repeats this cycle.
Anyone know what the issue could be or if there's anything I can try on my side besides the usual off/on & restart.
Thanks in advance
8 REPLIES 8
Fixes: 387
Re: Connection dropping
@MikeKilo92 Welcome to the forum. This sounds like an xDSL connection problem. Which Hub do you have?
MikeKilo92
Thanks for replying. I have the Hub 1. Just to reiterate this issue only started after an engineer went out to the green box to tweak my Download speeds. Nothing in my property has changed.
MikeKilo92
@jab1
Thanks for replying. I have the Hub 1. Just to reiterate this issue only started after an engineer went out to the green box to tweak my Download speeds. Nothing in my property has changed. I've also tried using a different ADSL filter but still nothing.
Thanks in advance
Fixes: 387
OK. Can you please provide the Hubs 'Help Desk' page (obscuring personal details) and the WAN tab from the Event Log, please?
MikeKilo92
@jab1
Sorry, but I'm not too sure on how to upload the pics on here. I don't see any option when Itype a message.
@MikeKilo92
To attach a picture to the  post click on the picture icon to the right of the smiley face above  Screenshot 2023-04-02 125558.png then follow the instructions.
HTH
MikeKilo92
@jab1
Not sure if that's it
Fixes: 387
@MikeKilo92 Looking at those pictures, although the log one is a little 'small text size', I would suggest you report a broadband issue, either by phone or the text service: https://www.plus.net/help/report-a-problem/broadband/ . Your connection is banded, and the downstream SNR figure is way too low - it should ideally be around 6dB, given your attenuation figures.
