Connection dropping
jdlb
Connection dropping
I've had plusnet for 3 weeks and although the speed is ok the connection drops all the time meaning that I can't stream anything for longer than 10 minutes or so. Any idea what causes this?
Gel
Seasoned Pro
Fixes: 12
Re: Connection dropping
jdlb
I've not had the chance to connect with an ethernet yet as the point is miles away from my computer/tv. I'll check the internet light next time it drops to see if it's the wifi or not.
Plusnet Staff
Plusnet Staff
Fixes: 159
We've seen a couple of disconnections but not a significant amount:
Let us know how it goes if you can test an ethernet cable.
 Chris Parr
 Plusnet Staff
jdlb
Thanks for the graphic, that's helpful. I've just switched to another socket that had been painted shut and things seem to be running much smoother! I think that may be problem solved.
