Connection dropping
- Re: Connection dropping
Connection dropping
02-11-2016 7:58 PM
02-11-2016 9:29 PM
03-11-2016 9:04 AM
I've not had the chance to connect with an ethernet yet as the point is miles away from my computer/tv. I'll check the internet light next time it drops to see if it's the wifi or not.
03-11-2016 11:13 AM
We've seen a couple of disconnections but not a significant amount:
Let us know how it goes if you can test an ethernet cable.
04-11-2016 3:02 PM
Thanks for the graphic, that's helpful. I've just switched to another socket that had been painted shut and things seem to be running much smoother! I think that may be problem solved.
