Connection dropping several times
patti
My connection started to drop yesterday and has continued today several times. I have reset my Router but it keeps happening. Any advice or is Plusnet having problems?
4 REPLIES 4
Fixes: 388
Re: Connection dropping several times
@patti :
If the phone test passes, report a broadband problem via: https://www.plus.net/help/report-a-problem/broadband/
The above assumes you still have 'normal' landline connection - if you have a SOGEA (internet only) one, just use the second link to report a network issue.
I suspect it is just you - otherwise there would be loads of reports.
patti
Hi John, Thanks for your reply. I have tested my landline and I can hear slight 'clicky' noises.. I have sent Plusnet a text so that they can investigate.
Fixes: 388
Let us know the response.
patti
Will do John.
