Connection dropping issues
manjitrai
My connection is dropping out many times a day for about 30secs to 1 minute each time. I have been using an ethernet cable and wireless too. Any chance someone could look at my line and find a solution since live chat isnt working?
Plusnet Staff
Plusnet Staff
Fixes: 159
Re: Connection dropping issues
We're seeing some disconnections but only up to 3 a day (which is higher than I'd like to see really).
Testing your line isn't showing any major problems either, the Mean Time Between Errors are both slightly below where I'd like to see them.
  Upstream DSL Link Information Downstream DSL Link Information
Loop Loss: 14.7 29.0
SNR Margin: 5.9 6.0
Errored Seconds: 6 7
HEC Errors: 0
Cell Count: 479076 1323704
Speed: 1040 16020
Maximum Stable Rate (KBPS): 2272 Fault Threshold Rate (KBPS): 2272
Mean Time Between Retrains (Seconds): 43174 Mean Time Between Errors Upstream (Seconds): 50
Indicative Line Quality: A Mean Time Between Errors Downstream (Seconds): 80
We can try increasing the SNR to 9db, which would result in a slightly drop in the download speeds but would help combat the errors on your line.
 Chris Parr
 Plusnet Staff
manjitrai
Yes a slight reduction in speed would be fine to increase stability but i just recently dropped about 2 times in 5mins
Plusnet Staff
Plusnet Staff
Fixes: 159
I've made the change, can you monitor until tomorrow and let us know how the stability is looking?
 Chris Parr
 Plusnet Staff
manjitrai
Sure
manjitrai
It seems the change has increased my latency making games unplayable when i usually have very few issues with latency. Will this vary of the next few hours?
manjitrai
Could interleaving be turned off as i feel like my ping been worsened after your changes
Plusnet Staff
Plusnet Staff
Fixes: 159
Interleaving shouldn't have come on, it wasn't changed in the request I put through. I've sent a request to turn this off fully but it's likely to get rejected until tomorrow I'm afraid.
 Chris Parr
 Plusnet Staff
manjitrai
Any other things u could change on the line to reduce latency?
manjitrai
High latency on wired connection
Im getting high latency while playing online games. I usually have low pings but after i had an issue with stability for the first time today my line has been altered therfore increasing my ping times
Fixes: 127
Re: High latency on wired connection
Moderators Note.
Topics merged to keep all info in one place
Will Moderate For Thanks
Plusnet Staff
Plusnet Staff
Fixes: 159
I've put a request through to remove interleaving and that's been accepted this morning. This should happen over the next few hours.
 Chris Parr
 Plusnet Staff
