Connection dropping every few minutes
- Connection dropping every few minutes
- « Previous
- 1
- 2
- Next »
Re: Connection dropping every few minutes
13-09-2012 11:46 PM
Quote from: w23 Most importantly it rules one more thing (filtered faceplate) out of the equation.
It's not unknown for them to be faulty and using the test socket will help to convince BT that all necessary tests have been done.
I ruled out several of the dangly filters during several phone calls to O2 when I had this problem less than a year ago.
BT fitted the socket. It's unlikely to be faulty since the problem disappeared after they'd fitted it (after the engineer had been to exchange) and my connection with O2 was great up until I switched to Plusnet.
I don't mind faffing about with it, but I know it'll make no difference. Also, with my line being limited at the exchange now, it isn't going to disconnect like crazy regardless of the filter. An engineer visit to our house is pointless, like it was last time, and I doubt BT will even agree to send one.
14-09-2012 12:07 AM
There's no real reason why changing to Plusnet should cause a problem with the same copper line though it's poosible if your O2 service was supplied on LLU then you will be connected to a different termination at the exchange.
14-09-2012 12:10 AM
I am sorry to hear that you're having problems with your connection again.
Although you've tried alternative microfilters before, it is always a good idea to bypass the filtered faceplate just to double check - We ask for our customers to do this to be sure that the fault isn't being caused by any internal equipment / wiring.
If your line remains stable at the restricted rate, we can always lift this restriction to see what exactly is going on as this will give us a better indication of what is going on. Our aim is to ensure that you have a stable connection whilst maintaining the fastest possible broadband speeds - This is what we will aim to do.
We will test your line and see if any issues can be identified. Ultimately, if we feel that an engineer is required, we will certainly send one out for you.
14-09-2012 12:18 AM
Quote from: w23 There's no real reason why changing to Plusnet should cause a problem with the same copper line though it's poosible if your O2 service was supplied on LLU then you will be connected to a different termination at the exchange.
I think that's what's happened.
14-09-2012 12:22 AM
Quote from: Chris Hi suebev03,
I'll try the microfilters supplied tomorrow in the test socket. My connection has been fairly stable at the 3Mb restricted setting though (Only disconnecting a few times a day), so I'm not sure what difference it'll make unless you can take the limit off to see?
14-09-2012 12:49 AM
14-09-2012 1:02 PM
14-09-2012 4:40 PM
While I think it's far too soon to tell, I can say that the connection has been on since you changed the filter and hasn't dropped since. Hopefully that'll stay the case over the weekend, but we'll see what happens.
17-09-2012 2:43 PM
EDIT: Ahhh, it's been reset. Just gotta wait 4 hours. Here's hoping no more disconnections.Though I doubt changing from the prefiltered to a dangly one has fixed it as apparently BT were investigating the fault.
18-09-2012 12:22 AM
18-09-2012 8:00 AM
these two will determine whether you should be getting faster throughput and if BT and PN match as they should.
but it should be all automatic.
18-09-2012 1:28 PM
The speedtester is giving me an error at the moment and the Plusnet page says my estimated line speed is 8Mb (varying from 6 - 14) and current line speed as 3.8Mb.
19-05-2013 3:45 PM
For the last two weeks my connection has been dropping like crazy every few minutes, past few days it seems to have stabilised... only at 3mb. After months of 13-16mb rock solid, can someone look into this?
Thank God we're getting FTTC in our area next year, ADSL technology needs to disappear forever.
20-05-2013 1:35 PM
I've checked over your connection and can see that your speed is now at 13.7Mb/s and your line has been stable for the past 24 hours.
I'd suggest to keep monitoring it over the next couple of days.
20-05-2013 6:44 PM
Quote from: chrispurvey Hi there,
Thank you very much. Been at 15Mb for the past 6 hours now. I suspect I'll be asking for someone to reset it or whatever again in a few months though.
- « Previous
- 1
- 2
- Next »
