Connection constantly drops! Help please!
tekkamanblade1
Firstly sorry about the caps.
I've been with plusnet since 2011, all good. Then I moved last November, all good till a couple of weeks ago.
I think my connection constantly drops. Now I'm a bit of a noob. So don't really know what happened. But I think I observed that the broadband will suddenly disconnect, and re-start connecting. This started about 2 weeks ago. Last week was pretty bad, I remembered there was a night it kept re-connecting after got connected. This week is better, but I estimate it will disconnect at least 5, 6 or even more a day.
I connect to internet through WiFi on all my devices. The router I use is the original router I had since 2011 from Plusnet. I tried to restart the router, and problem still exists. Also, I moved router's place a bit, not sure that helped hugely.
I was thinking of open a fault ticket, and actually half-opened one. However, I'm not comfortable about the concept of getting a new router and try my luck, as after reading a bit on the forum it almost is not user's equipment fault.
I would be much appreciated if any staff here could help me have a look. Thanks in advance!
Moderator's note by Mike (Mav): All caps title/text edited as per Forum rules.
10 REPLIES 10
tekkamanblade1
Re: Connection constantly drops! Help please!
This evening has been bad so far.
Fixes: 1,600
Hi there. Welcome to the community forums.
I'm sorry to hear you're experiencing connection problems.
Whilst our tests aren't finding a definitive cause of the drops which we can see, I've made a change to the settings on your line that should help stabilise your connection.
If the drops continue in a few hours I'd recommend running through the troubleshooting steps here next.
Let us know how you get on.
tekkamanblade1
Thanks Gandalf.
I think it's better than before. It had a few drop yesterday afternoon, but last night was good. Today afternoon I had a few drops.
I think it's almost like it only drops when I use internet.
Fixes: 1,600
Glad to hear things have improved.
If the problems return I'd recommend completing the broadband troubleshooter at http://faults.plus.net
Please let us know if you need any further assistance.
tekkamanblade1
Thanks Gandalf.
I think I might need to go through the troubleshooting. Just a couple of questions if I may.
So is there a router you would recommend me to get (only for test purpose)?
And I know I'm gonna move in 2 or 3 months, do you reckon the issue will be solved automatically if I move to a different place SG14 given my equipments are good?
EmilyD
Fixes: 117
Hi @tekkamanblade1,
Thanks for getting back in touch.
Any ADSL compatible router would be fine for testing purposes, as long as it's not locked to another provider. As you've mentioned that you're using your original router from 2011, there's a good chance that this could be an equipment issue. As a goodwill gesture, I've sent you a new router to try. You should receive this within 3-5 working days.
If the new router does not resolve the issue, it's unlikely that this is going to be something that will carry over to your new property. We are, of course, happy to work towards resolving the issue at your current property for as long as you need. Please let us know if your new router doesn't improve things.
 Emily D
tekkamanblade1
Thanks Emily.
Just for the record, things improved a bit. I only noticed 2 drops in the last 36 hours or so.
Will try the new router once it arrives and report back, thanks Smiley
Fixes: 1,600
No problems.
Keep us posted. Smiley
tekkamanblade1
I have been using the new router for a week now, and internet didn't drop once. So it was the router's problem in the end.
Thank you guys so much :)))))))
Fixes: 1,600
Glad to hear this is sorted now. Thumbs_Up
Thanks for coming back to us.
