Connection availability
djtuazon
I applied for a broadband connection last month and until now i havent had a connection. I tried calling them but just an operator is answering. I message them on facebook but they doesnt reply. I want to cancel my application with them since its been a month that my connection is still not available. Can anyone help me. Thanks
1 REPLY 1
Fixes: 251
Re: Connection availability
You cannot cancel on here.  Order for what?  FTTC or FTTP?
FTTP Order installation delays
In most instances FTTP installations will require two BT Openreach engineer visits...
  1. Install the fibre from the distribution block to the outside wall of the property, either overhead or underground
  2. Install the fibre from the outside of the property to the inside of the property to the location of the Optical Network Termination (ONT) unit
The fibre network is far from being fully established and in some cases specific engineering activities will be required for some installations. These circumstances are covered in Plusnet's T&Cs as follows...
Openreach Survey: In some cases, BT Openreach have to carry out a survey before they can connect a home to Full Fibre. To do this they may need access to your property. If they do we'll contact you to arrange a suitable time. If additional work is required, this may take longer than the initial set-up time provided and there could be additional costs. Our team of specialists will contact you to confirm what additional work is needed and how long this will take, usually within four weeks from the date your order was placed. If you don't want to proceed with your upgrade based on this, you will be able to cancel your order and no charges will be applied to your account.
To see what is happening in detail, check the ticket history on your account - log into the portal in another tab, return here and click the PN TICKET link below. Look at the details of the tickets; if there appears to be no recent activity, contact support.
Delayed orders
There are a multitude of reasons why order processing might be reported as delayed and usually it is nothing to be too concerned about, but there are exceptions. The following are some of the common causes of orders being delayed...
  • The user told their existing supplier that they are moving and the consequential action by their existing supplier will prevent any new ISP placing orders to take over the service - this needs affirmative action with the existing supplier
  • The existing circuit to the property cannot be identified in BT Openreach's systems due to errors in their data - this can give rise to the need for special processes (ORDI and Bridge cases) with BTOR to correct THEIR data
  • Something was not quite right with the order raised by Plusnet - these are usually sorted quickly
  • BT Openreach do not have engineering resources available in the usual timeframe
Contact Customer Options Team (aka COTS)
COTs is the place to go to if you want to find out anything to do with your contract in respect of leaving, renewing or simply enquiring about early termination charges (ETCs). They have their own number and tend to answer quicker than the general customer service number.
Direct dial numbers
  • 0800 013 2632 (from within the UK)
  • +44 330 123 9197 (from abroad)
  • Available...
    • 8am - 8pm Monday to Friday
    • 9am - 7pm Saturday
    • 9am - 6pm Sunday
