Connection and Usage Problems
- Connection and Usage Problems
22-02-2008 3:52 PM
1) I have an issue connecting to certain applications described here: http://community.plus.net/forum/index.php/topic,61331.0.html
2) Where has "View My Usage" gone from the Member Centre? I've got an "upgrade account" option instead - I can't find it anywhere!
Message 1 of 3
(1,129 Views)
2 REPLIES 2
Re: Connection and Usage Problems
22-02-2008 3:59 PM
Quote Where has "View My Usage" gone from the Member Centre?
The usage link seems to be replaced by an upgrade link about a month after joining!
However, "View My Usage" can be found by clicking on "Connection Settings" in the menu down the left of the page.
HTH
Paul
Message 2 of 3
(352 Views)
26-02-2008 5:02 PM
Thanks Paul. Found it. Seems odd - I don't like it. I use the view my usage a lot more than I'm ever going to use any upgrade option. Further, if people want to upgrade that's a significant act that they will have spent a little time considering, ergo they will look harder for the facility to do so.
View my usage is essential for those of us who aren't used to bandwidth caps and fingertip access to this feature is much more useful.
Message 3 of 3
(352 Views)
