Connection & Speed Issue - Help Admin
Trix
Ive been with Plusnet for about 20 days now and had constant problems with connection drops and speed. After alot of tickets and phone calls with plusnet 'technical' staff i am still stuck with a super slow speed.
On the first day of connection I was getting 6500 which was great but then it suddenly dropped to 500, after speaking to technical staff he assured me after a 10 day 'stabilisation period' it would get faster. I waited for the 10 days to pass and it was still at 500 so i spoke again to staff who said after 72 hours BT would update our profile and it will be sorted, 95 hours passed and I still had the same issue. Another phonecall later and a couple of days passing our profile was updated to 3500 but it only lasted for less than 24 hours, I have taken over taken over 10 bt speed test as was requested.
Im paying for the 60gb download and an extra £5 per month for the pro addon which atm is a total waste of my money
I seem to be hitting a brick wall when i phone up now as they offer me no more help or offer assistance in anyway, i just seemed to be getting fobbed off which is unfair as im paying for a service which i am not recieving
Is there any Admin on that could offer me any help
my router is a thomson tg585 v8
21 REPLIES 21
Oldjim
Resting Legend
Fixes: 63
Re: Connection & Speed Issue - Help Admin
Please post the following
Router stats - speeds, noise margin and attenuation from here
Result of BT speedtest from here
Current line speed from here
Trix
Current line speed
Phone exchange:
MOSSLEY
Estimated line speed:
5Mb (This may vary between 4Mb and 8Mb) - Checked on 2011-05-01 22:59:39
Current line speed:
0.5 Mb
Router stats
Downstream Upstream
Rate (Kbps): 687  443
SNR Margin (dB): 6.9  15.6
Attenuation (dB): 40.5  23.9
Output Power (dBm): 11.5  0.0
BT Speedtest
Test1 comprises of two tests
1. Best Effort Test:  -provides background information.
Download Speed
445 Kbps
0 Kbps 500 Kbps
Max Achievable Speed
Download speedachieved during the test was - 445 Kbps
For your connection, the acceptable range of speedsis 100-500 Kbps.
Additional Information:
Your DSL Connection Rate :686 Kbps(DOWN-STREAM), 443 Kbps(UP-STREAM)
IP Profile for your line is - 500 Kbps
The throughput of Best Efforts (BE) classes achieved during the test is - 20.88:21.95:57.19 (SBE:NBE:PBE)
These figures represent the ratio while sententiously passing Sub BE, Normal BE and Priority BE marked traffic.
The results of this test will vary depending on the way your ISP has decided to use these traffic classes.
2. Upstream Test:  -provides background information.
Upload Speed
361 Kbps
0 Kbps 443 Kbps
>Upload speed achieved during the test was - 361 Kbps
Upstream Rate IP profile on your line is - 443 Kbps
Oldjim
Resting Legend
Fixes: 63
There is a major problem.
Can you connect the router to the test socket with nothing else connected and report the stats again.
Are you absolutely sure everything is filtered including Sky Box
Trix
Hi
We havent got a test socket in the property, the router is plugged into the main socket.
We havent got Sky and everything is filtered.
Oldjim
Resting Legend
Fixes: 63
Can you try another filter without a phone connected and report the stats
Trix
Router Stats
Rate (Kbps): 543  443
SNR Margin (dB): 25.2  15.4
Attenuation (dB): 42.0  23.9
Output Power (dBm): 11.6  0.0
BT Speedtest
Download Speed
445 Kbps
0 Kbps 500 Kbps
Upload Speed
361 Kbps
0 Kbps 443 Kbps
Trix
missed this
Phone exchange:
MOSSLEY
Current line speed:
0.5 Mb
Oldjim
Resting Legend
Fixes: 63
Can you disconnect the router and reconnect still with nothing else connected and report the stats again.
The reason is the reported noise margin of 25.2dB which indicates that the line has suddenly improved
Trix
BT Speedtest
Test1 comprises of Best Effort Test:  -provides background information.
Download Speed
353 Kbps
0 Kbps 500 Kbps
Download speedachieved during the test was - 353 Kbps
IP Profile for your line is - 478 Kbps
The throughput of Best Efforts (BE) classes achieved during the test is - 9.77:26.48:63.9 (SBE:NBE:PBE)
If you wish to discuss these results please contact your ISP.
If you are experiencing problems with specific applications, servers or websites please contact your ISP for assistance.
Your test has completed please close this window to exit the performance tester.
Note: An Upstream test was not conducted on this line due to a technical issue. If your concern is related to upstream performance then please retry
the performance test again in 1 hours time.
Router Stats
Downstream Upstream
Rate (Kbps): 4543  443
SNR Margin (dB): 6.3  24.3
Attenuation (dB): 41.0  23.8
Output Power (dBm): 13.2  0.0
Plusnet member centre
Phone exchange:
MOSSLEY
Current line speed:
0.5 Mb
Oldjim
Resting Legend
Fixes: 63
Downstream Upstream
That indicates that the interference has gone even if only temporarily.
There is no need to do BT speedtests as that won't change until  the IP profile increases.
The next thing is to find out what is causing the problem.
Using the present filter what happens to the router stats when the phone is connected, when the phone is used and when someone rings you.
No need to unplug the router just do the above seeing if the router stats change
Trix
  Downstream Upstream
SNR Margin (dB): 5.8  24.8
did a speedtest
Trix
when phone is in use
Downstream Upstream
SNR Margin (dB): 5.8  19.4
Oldjim
Resting Legend
Fixes: 63
I assume, as suggested earlier, you changed the filter.
If so it appears to have been a duff filter
Note that there is no point in doing speed tests as nothing will improve until the IP profile increaseI suggest leaving everything alone now and check the router stats tomorrow.
If it holds the sync speed then the IP profile should increase in a couple of days. Disconnecting and reconnecting the router will only delay this
jojopillo
Hi Trix,
I can see it's back with the faults team, but if your sync rate stays as it is, it shouldn't be too long before your speed returns.
Jojo Smiley
