Connection Timing Out After Few Mins
seanwinf
Iam on plusnet value with the pro add on but everytime i try and download anything it just times out? been trying to download the new software for my phone from samsung and the most its got to is 53% then times out? phoned customer service they said try the pro add on but still not doing anything!!
seanwinf
Re: Connection Timing Out After Few Mins
also notice its normal web pages that drop refresh or if i click something it dont respond first time. got a brand new asus router, and tried 2 different filters all the same from what i can see
seanwinf
Download speedachieved during the test was - 3123 Kbps
Additional Information:
Your DSL Connection Rate :4128 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 3500 Kbps
Fixes: 68
The results from the speedtest look to be OK.
Are you trying to do the software download over wireless? And what operating system is on your PC?
David
seanwinf
ive tried over wireless and wired still the same, i have also tried windows 7 but now back on vista and still the same, ive been trying to update windows aswell and just times out! so not the software
Fixes: 24
You should look at your router stats and see how long the connection has been "up".  If your broadband connection is dropping-out frequently then the download may well time-out before the router can re-establish it.
seanwinf
thats whats happening, the connection is dropping so timing out the download or stream, my up time is constant.
Fixes: 24
Yes, but there are various points at which the connection could drop.  Your router should be able to tell you how long it has been powered-up and how long it is since it last re-established the internet connection.  That will tell you whether what is dropping is the broadband connection to your router or the connection between your router and your computer.
jojopillo
Hi seanwinf,
There are a few disconnections around the time of your first post, but since then it seems to have stabilised. What are you seeing at your end now?
Jojo Smiley
seanwinf
think those are from where i have tried turning off, its still doing the same thing, just keeps timing out
seanwinf
Dont know if this helps or not?
lexusuk
From our line tests and connection logs we aren't seeing any issues with your connection at the moment that would result in these time outs.  You are connected stable at just over 4Mbps.
My suggestion would be to test your line with another machine if possible or test your current machine on another broadband connection to ensure the issue is not related to your computer.
seanwinf
cant be my computer because ive reinstalled windows, tried it on windows 7 and vista and still doing the same, could there be a setting on my router thats making it do it? i did a factory reset last nite and still the same after that
Is it a wireless connection between your router and PC, and if so could it be that that's dropping?
seanwinf
its wireless and wired, happening on both
