Connection Timing Out After Few Mins
- Re: Connection Timing Out After Few Mins
06-08-2011 3:23 PM
06-08-2011 3:43 PM
06-08-2011 4:01 PM
Additional Information:
Your DSL Connection Rate :4128 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 3500 Kbps
06-08-2011 11:50 PM
Are you trying to do the software download over wireless? And what operating system is on your PC?
07-08-2011 9:39 AM
07-08-2011 9:44 AM
07-08-2011 7:03 PM
07-08-2011 10:31 PM
08-08-2011 4:23 PM
There are a few disconnections around the time of your first post, but since then it seems to have stabilised. What are you seeing at your end now?
Jojo
08-08-2011 6:44 PM
08-08-2011 6:56 PM
09-08-2011 11:13 AM
My suggestion would be to test your line with another machine if possible or test your current machine on another broadband connection to ensure the issue is not related to your computer.
09-08-2011 6:00 PM
10-08-2011 2:09 PM
10-08-2011 4:57 PM
