Connection Speed
- Connection Speed
Connection Speed
01-04-2013 11:50 AM
hi, I've had a banding removed from my profile today, thanks first of all, and am now wondering do I go through another 10 learning period with the line. I say this as my speed is showing just under 3Mb while my router is reporting a bit faster.
ADSL Link Downstream Upstream
Connection Speed 3913 kbps 444 kbps
Line Attenuation 52.0 db 32.1 db
Noise Margin 6.7 db 19.6 db
BT Wholesale is reporting 2.9 Mb.
Will the line improve speed during the next week, or is there a bottleneck I need to address?
Message 1 of 5
(864 Views)
4 REPLIES 4
Re: Connection Speed
01-04-2013 11:52 AM
Those speeds - from a speed test I assume - are about right for your sync speed so leave everything alone and don't switch of the router for the next 10 days
Message 2 of 5
(490 Views)
01-04-2013 12:02 PM
Thanks, I take it I'll see a small improvement by the end of that time?
Have to say, after some initial faffing about, things have been dealt with pretty well. The only delay was due to the 10 learning period having to end before a new one is started, no fault of Plusnet I suppose.
Message 3 of 5
(490 Views)
01-04-2013 12:12 PM
Most unlikely
For information
Your IP profile (from a BT speedtest) will be 3,451kbps and the Plusnet mirror of it 3,400kbps which should give a speed test result of about 3Mbps
For information
Message 4 of 5
(490 Views)
03-04-2013 10:10 AM
Message 5 of 5
(490 Views)
